Activity Forums Media 100 different gamma when importing Uncompressed 10 bit HD
  • different gamma when importing Uncompressed 10 bit HD
    Posted by Fermin Branger on May 4, 2010 at 7:45 pm
    Hi, I have to work with Uncompressed 10 bit HD video but when I import it (to ProResHQ) I get the image with totally different gamma, Blacks and highlights hypercontrasted.
    How can I work with this media without loosing the original dinamic range of the image?
    Fermin Branger
    ALFARERIA CINEMATOGRAFICA
    Caracas, Venezuela.
    Floh Peters replied 16 years, 4 months ago 2 Members · 3 Replies
  • Floh Peters
    May 5, 2010 at 2:48 pm
    hmmm, where do you export it from; in other words, if you have Uncompressed HD material, how do you convert it to ProRes?
  • Fermin Branger
    May 5, 2010 at 3:03 pm
    Thanks Floh,
    ..when importing from M100 (checking import media to the media standard and codec). Before that, I made a test converting trough Quicktime with great results, but without time code, and I need it to replace media for online version before export to DPX.
    fermin
    Fermin Branger
    Caracas, Venezuela.
  • Floh Peters
    May 5, 2010 at 6:49 pm
    This probably is related to a transcoding issue; when exporting a QuickTime you can select either full RGB0-255 range or video RGB16-235 range. Unfortunately you cannot do that for file imports, so all incoming files will be treated as if they have a 16-235 range. Since you are feeding in a 0-255 image you get too much contrast. This is for conversions only, though, so all files that do fast-import come in correctly.
