Activity › Forums › DaVinci Resolve › Different frame rates in the same project?
  • Different frame rates in the same project?
    Posted by Alexandre Cristófaro on April 26, 2012 at 4:20 pm
    Hello, this a question I often have to deal with. I know that’s a editor’s / camera operator’s fault but it’s really common that it’s left for me to deal with it.
    I have a timeline in FCP that’s set to 29,97 720×486 because the editor tought it was a good idea to set it that way since the final output will be a BETA tape. But the original files comes from variable sources. I have 5D prores at 1920×1080, 1280×720 at 29,97 fps and at 23,976. And DVCPROHD 960×720 at 23,976.
    I found that is impossible to conform that timeline to Resolve. So I was left with two options: Export a closed movie from final cut changing the timeline to FULLHD and fit everything to it and cut it in Resolve. But then I would have to assume the awful scale and frame rate adaptation from Final Cut. (much better scaling in resolve!)
    Or the other that I choose to go with was to separate the timeline in two: one at 23 and other at 29, both 1920×1080 and send that to resolve so that I’m able to use the great scaling algorithms from resolve and do a online edit after with resolve out.
    That seemed to work fine, but the question is: Can I have two timelines with different frame rates in the same project in resolve or I have to create one different project to each timeline? The timeline framerate option in the configuration tab seems to be global to the entire project! Is there anyway that I can have both timelines in one project?!
    Thank you all
    Alexandre Cristófaro replied 14 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
