Activity Forums VEGAS Pro Different file setting on one DVDA disk
  • Different file setting on one DVDA disk
    Posted by Paul Gregory on December 19, 2012 at 2:53 pm
    I set DVDA 5.2 to create a Blu-ray project as the top 1920×1080 template & drag in a file which it tells me is compliant & doesn’t need to be rendered. I’m led to believe that I should then be able to also add to this project any other AVC or MPEG2 compliant file to be included on disk without re rendering. How is this achieved? When I go to drag another file in it says that the project is set for the original settings & what I want to add will be re rendered because it’s not the project setting? Can the different resolutions/bit rates all exist on the same disk without re rendering?
    Thanks in advance
    Paul Gregory replied 13 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
