Activity › Forums › VEGAS Pro › different effects to text
  • different effects to text
    Posted by Adan david on September 12, 2026 at 4:52 am
    does anyone know how to apply different effects to every single element (like each individual text) when using 3D Camera? i’m trying to make each text/element have its own effects and settings instead of the effects applying to everything together. is there a proper way to do this while still using the 3D Camera?
    Silviu Negoita
    replied 2 weeks, 2 days ago
    2 Members · 1 Reply
  • Silviu Negoita
    September 12, 2026 at 11:20 am
    The easiest way is to keep the text elements separate. If everything is inside the same event/group, any effects you add there will affect the whole thing.
    I usually put each text element on its own track/event and then apply the effects individually. You can still use the 3D Camera for the overall scene — the camera handles the 3D movement while each text element can have its own effects, position, rotation, etc.
    Also check where you’re applying the effect. If it’s being added at the track/parent level instead of the individual event, that’s why it’s affecting everything together.
    This tutorial shows a pretty good example of working with text and a 3D camera:
    https://www.youtube.com/watch?v=Mf8FKh7dOQU
