Activity › Forums › Adobe After Effects › Different color depth for different compositions in a same project?
  • Different color depth for different compositions in a same project?
    Posted by Daniel Gómez on June 19, 2014 at 12:39 pm
    Hello,
    I exported from Premiere to After Effects, 10 clips to a single project using Dynamic Link. Each clip is a composition in After Effects, so now I’ve got 10 compositions.
    I want to work at 16bpc on five compositions, and 32bpc on the other five. How can I change the color depth of some compositions without affecting the rest of the project, and watch them in Premiere with their own color depth?
    Thanks a lot.
    Walter Soyka replied 12 years, 3 months ago 2 Members · 1 Reply
  • Walter Soyka
    June 19, 2014 at 2:54 pm
    Bit depth is a per-project setting, not a per-comp setting. It’d probably be best here to split your project into two.
    If you need to force 16-bit clipping between two layers in a 32bpc project, you could insert an adjustment layer with CC Composite on it.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
