Activity › Forums › Adobe Premiere Pro › Different Audio Handling in PPro2?
Shane Chadder
January 22, 2006 at 1:58 amOh it is a fun one to find.
If you are in your Bin, er I guess Adobe calls it “project”, select a clip. Go up to the top menu and select clip, audio options, source channel mappings. There you will find the toggle that will allow you to change a stereo track to two mono tracks the next time you put the clip on the timeline.
I’m not sure it is worth it when you have to set this for all your clips before you edit. This needs to be a global setting like setting stills to 150 frames is.
Shane
Ken Adolph
January 22, 2006 at 2:19 amThanks Shane
I found it and yes you can’t apply this to all the clips in the bin. This makes it almost useless.Ken Adolph
Media Group
Editor/Post Supervisor
https://www.mg.ca -
Ron Shook
January 22, 2006 at 3:46 amKen & Shane,
[ken adolph] “I found it and yes you can’t apply this to all the clips in the bin. This makes it almost useless.”
Jacob said on this thread, “You cannot run a batch process, but as long as all the captured clips have the same captured audio settings, you can select all the clips and execute the same remap on the ones selected.”
I assume that audio remapping must also be turned on, whatever that means. Test this out. If it doesn’t work, I’m gonna go Cherniak Ballistic. (g) Drilling down 4 layers of menu to do this on each clip is impossible.
Ron
Ken Adolph
January 22, 2006 at 4:27 amOK!
I apologize for not re-reading Jacob’s post compeletly after Shane showed me where the setting is!
When I selected muliple clips I also selected the one that I just changed and of course it does not have the same audio settings.
This remapping does work for all clips with the same audio when you multi select them in the bin.
This is great.Ken Adolph
Media Group
https://www.mg.ca -
Ron Shook
January 22, 2006 at 9:11 am[ken adolph] “This remapping does work for all clips with the same audio when you multi select them in the bin.”
Whew!!!
Ron
