Activity Forums Apple Final Cut Pro Legacy Different aspect ratios on same exhibition disc
  • Different aspect ratios on same exhibition disc
    Posted by Erick Stoll on May 13, 2011 at 9:26 pm
    I’m preparing a Blu-Ray disc for exhibition at a local film festival, and I’ve run into a problem: 4 of the 5 films are in 16×9 HD, but one is 720×480 (a standard def transfer of a 16mm film).
    When I previewed the disc in encore, all five films displayed correctly, but when I did a test run at the theatre, the 720×480 was distorted. The projector, which was in 16×9 mode, will not adjust automatically, nor do we want to change the projector setting in between films.
    How can I add “letter boxes” to the side of the 720×480 film in compressor to make it play back correctly?
    Chris Tompkins replied 15 years, 4 months ago 2 Members · 1 Reply
  • Chris Tompkins
    May 13, 2011 at 11:12 pm
    Put the finished master in FCP into a 16×9 Sequence.
    Make adjustments/additions (black boxes)
    Export a 16×9 file.
    Compress for Bluray.
    Chris Tompkins
    Video Atlanta LLC
