Activity Forums Adobe Encore DVD Different aspect ratios on same exhibition Disc
  • Different aspect ratios on same exhibition Disc
    Posted by Erick Stoll on May 13, 2011 at 9:26 pm
    I’m preparing a Blu-Ray disc for exhibition at a local film festival, and I’ve run into a problem: 4 of the 5 films are in 16×9 HD, but one is 720×480 (a standard def transfer of a 16mm film).
    When I previewed the disc in encore, all five films displayed correctly, but when I did a test run at the theatre, the 720×480 was distorted. The projector, which was in 16×9 mode, will not adjust automatically, nor do we want to change the projector setting in between films.
    How can I add “letter boxes” to the side of the 720×480 film to make it play back correctly?
    Daniel Ludwig replied 15 years, 4 months ago 2 Members · 1 Reply
  • Daniel Ludwig
    May 14, 2011 at 9:19 am
    eric,
    you need to be sure your SD-file is flagged as 16:9, but there are a few players, that wont display it correctly.
    please look at your player-settings if it will force display to 16:9 or automatic.
    cheers
    danny
