Activity › Forums › Adobe Premiere Pro › Differences between Pro & elemets
  • Differences between Pro & elemets
    Posted by Perry Cheng on December 24, 2007 at 12:53 pm
    Is there a site where it lists the comparison features between pro and elements for Photoshop and Premiere? I thought it would be on Adobe, but I can’t find it. If this does not exist, anyone can give me a quick run down?
    e.g. Premiere elements (Pe) = no nesting / multisequences
    no quick color correction????
    Adobe elements (Ae) = no multilayers?
    Perry
    Mike Velte replied 18 years, 9 months ago 2 Members · 3 Replies
  • Mike Velte
    December 24, 2007 at 2:42 pm
    Download a demo of each and try.
    Premiere Elements 4 bears little resemblance to Pro in workflow and features. It is really SIMPLE…tooo simple for you. It has none of its own magic features like Photoshop Elements. Very little one learns from Premiere Elements can be applied to Pro, unlike Photoshop Elements.
    While Photoshop Elements is a cut down version of Photoshop, it is still quite powerful. It has many undocumented features of the full version kinda hidden, like holding the Alt key down while adjusting levels to see what is being crushed. Most of what one learns in the Full Edit mode can be applied to the full version of Photoshop.
    I teach both on occasion at a local Career Tech school. I run out of things to teach in PE after about 8-10 hours, but PSE class runs 24 hours and leaves students overwhelmed and awed at the possibilities.
    Premiere Elements 4 is quite similar to Movie Maker in worlflow.
    Photoshop Elements 6 is quite similar to Photoshop plus a lot of extras.
  • Perry Cheng
    December 24, 2007 at 5:25 pm
    Mike,
    Thanks. So, am I correct that PSE does not have layers? Or am I wrong? Also, PE does support 24p pulldown?
    Perry
  • Mike Velte
    December 25, 2007 at 11:55 am
    PSE has layers, but no masks or channels or layer comps.
    APE has 2 project settings if you will, NTSC DV and PAL DV. It will import a lot of formats that Pro cant.
