Activity › Forums › Apple Final Cut Pro Legacy › Differences between FCP movie export and QT Export??? recompresses?
  • Differences between FCP movie export and QT Export??? recompresses?
    Posted by Paul Harb on December 22, 2005 at 7:35 pm
    If I am working in a DV timeline and want to export a full rez QT of my program, what is the best method for doing this? This movie will be going to another machine for captioning. When I do a FCP movie export, it flys through the export….but when I do a QT movie conversion, even at DV rez, it takes forever….this makes us wonder what is FCP doing to the DV stream to take so long? IS it actually recompressing (degrading the picture)? Am I better off exporting as a FCP movie then converting to QT outside of FCP? Thanks…
    Paul
    Dave Gardner replied 20 years, 1 month ago 6 Members · 12 Replies
  • 12 Replies
  • Don Greening
    December 22, 2005 at 7:44 pm
    Export a self-contained QT movie from FCP. Use the same export presets as your timline. This will allow you to put the movie on an external drive for use on another computer. Export using Quicktime conversion will encode the movie to a different codec such as MPEG2 for use on a DVD, so that’s why that particular method is taking so long when you export that way.
    – Don
  • Paul Harb
    December 22, 2005 at 8:18 pm
    I understand how it all works, I guess my question is if I set up my QT conversion to the same settings as my timeline, the movie is the same exact size if I export it as a FCP self contained movie…..so why is it taking longer? Is it actually recompressing to DV even though it already is coming from a DV timeline? Is it degrading the picture in any way? When would you use QT Conversion export and set it to your timeline settings, or is this redundent…..
    Paul
  • Don Greening
    December 22, 2005 at 8:32 pm
    [paul] “Is it actually recompressing to DV even though it already is coming from a DV timeline?”
    Well it must be, otherwise it would take the same amount of time to export as using the simple “Export Quicktime Movie” command does.
    [paul] “When would you use QT Conversion export and set it to your timeline settings, or is this redundent…..”
    Beats me, although there must be a reason to have the choice available or they wouldn’t include it in the export options. Would They? There has to be a reason why it’s in there. Since I’ve never had the need to export a DV movie using the Quicktime Conversion command plus using the same exact DV codec I’ve no idea what kind of quality hit there’d be. If any. Why not take a 5 min. piece of your project and encode it to see what happens to the quality as compared to the simple “export QT movie” command.
    – Don
  • Graeme Nattress
    December 22, 2005 at 9:25 pm
    “File -> Export -> Quicktime Movie…” good – use default settings, make self contained. Best quality output
    “File -> Export -> Quicktime Conversion…” – only use for making web movies or you’ll incur problems with repeated Y’CbCr -> RGB -> Y’CbCr and other nasties.
    Graeme
    – http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Paul Harb
    December 23, 2005 at 12:36 am
    thanks, makes sense……
  • Daniel Sanz
    December 23, 2005 at 10:22 am
    Although I can
  • Martin Baker
    December 23, 2005 at 10:26 am
    Exporting as a reference movie does this:
    * Renders any unrendered or RT effects in the sequence
    * Creates a new QT file with LINKS to either the source clips or render files as appropriate (this takes very little time)
    Exporting as a self contained movie does this:
    * Copies the relevant source clip or render file MEDIA into the exported QT
    So there is no additional compression going on with either path but if any parts of your sequence are showing as RT effects then they will have to be rendered first. Assuming the sequence is fully rendered then exporting as reference movie will always be far faster than self-contained because FCP doesn’t have to copy large media files from one QT to another.
    As Graeme says, avoid the “Using QuickTime Conversion” option as this goes through YUV-RGB-YUV which is not desirable.
    Martin
    Digital Heaven, London UK
    ________________________________________
    NEW! MovieLogger – QuickTime logging made simple
  • Dave Gardner
    August 3, 2006 at 1:56 pm
    I hope an expert can weigh in on what I’m seeing with my own eyes here. The manual indicates export > QT conversion always recompresses everything. But here is what I’m seeing on a 22 second test clip:
    Using Export > QT movie (current settings) I get 80.9MB self-contained or 43.8MB ref. movie, but it looks soft when I play it back with the QT Player.
    Using Export > QT Conversion , selecting “uncompressed” and “best” quality, I get a huge file (446.4MB), but it is noticeably sharper when I play it back with the QT player.
    I am going to use the resulting file to create Flash video using Flix Pro. Can’t imagine why Export > QT movie gives me such a soft image. Anybody???
    Dave Gardner
    Producer/Director/Writer
    Visions West
    Breakthrough Communication for World-Class Companies
    Colorado Springs * Dallas * Atlanta
    Main Office:
    760 Wycliffe Drive
    Colorado Springs,
  • Martin Baker
    August 3, 2006 at 6:02 pm
    It’s soft because older versions of QuickTime Player do not display DV movies at high quality on screen. This is a historic hangover from the days when decoding a DV movie at full quality and frame rate was on the edge of what was possible with the processors.
    In 2006 it’s not a problem, so the current version of QuickTime Player provides a preference called “Use high-quality video setting when available”. If that is checked then DV movies will play at full resolution and not look soft. Uncompressed movies always play at full quality which is why your export looks much sharper.
    Regardless of whether it looks soft when played in QuickTime Player any further compression you do to the file will always be done at full quality.
    Martin
    Unique plug-ins and tools for Apple Pro Apps
    NEW! BigTIme – resizable timecode display for FCP
  • Dave Gardner
    August 3, 2006 at 6:08 pm
    Thanks, Martin, for the great explanation. Why the big difference in file size, though? By the way, I love your plug-ins for FCP and plan to purchase some of those!
    Dave Gardner
    Visions West
    Main Office:
    760 Wycliffe Drive
    Colorado Springs,
