Activity Forums Apple Final Cut Pro Legacy Differences between FCP 5 and FCP 7
  • Differences between FCP 5 and FCP 7
    Posted by Grant Wilber on July 29, 2011 at 2:29 pm
    I recently upgraded from FCP 5 to FCP 7 and was wondering if people could tell me any big changes in either efficiency, effects, or anything else. I’m diving straight into editing a pile of projects I got so don’t really have time to go through and find all the new features as I’d like. I’m sure I’ll discover them as I go but am just curious if theres any big changes so I don’t find anything out after the projects are done.
    I already found smoothcam which is pretty incredible. And I know multicam is supposed to be alot better.
    Using Canon DSLR’s so I think my importing is the same (using Mpegstreamclip to convert 1st).
    Rafael Amador replied 15 years, 1 month ago 5 Members · 4 Replies
  • David Roth weiss
    July 29, 2011 at 3:42 pm
    The ProRes codecs are the biggest difference. And, Log and Transfer will actually allow you to ingest your DSLR footage properly from memory cards without using Streamclip.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Don’t miss my new tutorial: Prepare for a seamless transition to FCP X and OS X Lion
    https://library.creativecow.net/weiss_roth_david/FCP-10-MAC-Lion/1
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Jeremy Garchow
    July 29, 2011 at 3:43 pm
    You should check out the free plugin from Canon that uses the FCP log and transfer interface to turn your DSLR footage to ProRes.
    ProRes, that’s another big change form 5 to 7
    As far as interface, they are pretty similar. The log and transfer window is a bit different with more options.
    Jeremy
  • Andrew Rendell
    July 29, 2011 at 7:51 pm
    One thing I particularly like is the way you can create speed change sequences in 7 by putting markers on the video track and dragging them to where you want that frame to be…
  • Rafael Amador
    July 30, 2011 at 10:05 am
