Activity Forums Adobe After Effects Difference Node similar to Nuke?
  • Difference Node similar to Nuke?
    Posted by Sean Dunn on August 16, 2016 at 4:28 pm
    Hey all,
    Does anyone know of a plugin or preset similar to the Difference node in Nuke to be used in after effects?
    I’m trying to view if there’s any change in the pixels or not. If both images are in correct color space and position, the screen will be black because the identical pixels cancelled each other out.
    Sean Dunn replied 10 years, 1 month ago 1 Member · 3 Replies
