Activity › Forums › Boris FX › Difference Keying?
  • Difference Keying?
    Posted by Jaeson Koszarsky on November 12, 2009 at 4:01 pm
    Hello,
    I’m using BorisRED v4 with Media100HD.
    The object removal plug-in (motion key) looks interesting. I haven’t actually tried it yet. But I’m wondering if the reverse can be accomplished. Rather than removing a moving object from a static background, can you key out the static background and keep the moving object?
    Jaeson
    Steve Pankow replied 16 years, 10 months ago 4 Members · 3 Replies
  • Peter Mcauley
    November 12, 2009 at 5:08 pm
    Hi Jaeson,
    The BCC Motion Key filter is capable of removing foreground objects from a background but the filter has no way to isolate the foreground object and composite that on a separate background. It’s something that has been discussed internally in the past though and we may offer that in a future revision of BCC.
    Cheers,
    Peter.
  • Boris Yamnitsky
    November 12, 2009 at 5:10 pm
    Although Motion Key filter was not designed for this task you can try to apply a difference key with the original. I expect you may see problems with the edges but you can further refine the edges with a matte choker. In other words you’ll have to experiment. Good Luck.
    Boris Yamnitsky
    BorisFX
  • Steve Pankow
    November 12, 2009 at 8:52 pm
    Or BorisFX could just buy out Imagineer Systems 😉
