Activity Forums RE:Vision Effects Difference between Twixtor Render-only version1 and Full Version
  • Difference between Twixtor Render-only version1 and Full Version
    Posted by John Mark on September 13, 2013 at 2:17 pm
    I am thinking of buying Twixtor, to do frame-rate conversations, for a video play-out. Looking at the price of Twixtor its a little pricey, for the full version for After Effects. So what is the difference between the Render-only version1 and the full version. Saves me from paying extra for simple thing I need.
    Thanks.
    A News Graphic Lover
    Peter Litwinowicz replied 13 years ago 2 Members · 1 Reply
  • Peter Litwinowicz
    September 13, 2013 at 3:34 pm
    A render-only license is not useful to you without a full license. Simply put: the render-only license will work for you. From our website:
    Render-only licensing note: Render only licensing is for use with After Effects’ render-only program (aerender). Render-only licenses do not work in AE’s Render Queue (for Render Queue rendering you need the full version). Note that the Twixtor render-only licenses only work on projects written with a full license (so you must have at least one full license for the render-only licenses to be valid).
    Pete
    RE:Vision Effects, Inc.
