Activity › Forums › Apple Final Cut Pro Legacy › Difference between the two audio transiions.
  • Difference between the two audio transiions.
    Posted by Scott Davis on April 30, 2005 at 3:44 pm
    It must be all that loud rock and roll music ruining my hearing; but I can’t tell a difference between the +3db and the 0db audio transitions. What exactly (both in a technical sense and a perceived sense) are the differences?
    Once again, thanks to all.
    Scott Davis
    John Fishback replied 21 years, 5 months ago 2 Members · 1 Reply
  • John Fishback
    May 1, 2005 at 3:08 am
    0db is a linear transition where you might hear a slight “dip” in sound in the center of the transition. +3db should appear to have an equal transition from one sound to the other. You probably will want to use the +3db transition most of the time.
    Dual 2.5 G5 4 gigs RAM OS 10.3.8 QT6.5.2
    Cinema 23 Radeon 9800
    FCP4.5 DVDSP 3.0.2
    Huge U-320R 1TB Raid 3 firmware ENG12.BIN
    ATTO UL4D driver 3.20
    AJA IO driver 1.3.1 firmware v21-26
