Difference between ‘Slide’ and ‘Push’ transitions?
Anyone know what the difference is between the “Slide” and “Push” transition within the ‘Slide Folder’ within Transition Effects? It seems that they are exactly the same when I test them out, but I’m sure there is a difference somewhere… anyone know?
Also, I am looking for a transition that has the same effect as Slide, but instead of sliding it horizontally, I’d like the transition to be vertical. Anyone know of one? Thanks for your help!
