Difference between SD DVD created from Apple Prores 422 and DV PAL
Hello there,
I want to know that what would be difference between in the following:
1. I have an Apple Prores 422 1080p HD video, if I create a DVD directly via using toast, what quality it will give me?
2. if I have an Apple Prores 422 1080p and I convert it to DV Pal first then create DVD using toast. what would be the quality.
and if we compare these two DVDs on a same screen at the same time, would result be noticeable?
Can anyone please help?
Thanks In advance.
Azee
