Activity › Forums › Adobe After Effects › Difference between Rendering and “Make Movie”
Posted by Erin Patrick on May 9, 2006 at 2:41 pmCan anyone tell me? The help files are so vague.
Erin Patrick replied 20 years, 3 months ago 4 Members · 10 Replies -
Aharon Rabinowitz
May 9, 2006 at 2:49 pm“Make movie” sets up a composition for Render. It opens the render queue and gives you the ability to change the setting for final output. Once set up, you hit the render button.
Rendering is the process of taking your comp and outputting it as a video file (or image sequence or audio file or whatever).
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com -
Aharon Rabinowitz
May 9, 2006 at 3:02 pmIt’s the difference between sitting down in your car and adjusting the seat and mirror, and actually driving.
Make movie is adjusting your car seat and mirror.
Rendering is driving.
Aharon Rabinowitz
Erin Patrick
May 9, 2006 at 3:13 pmBut at the end of both you have a video file (or image sequence or audio file or whatever), right?
I hope this isn’t a stupid question, but I really want to understand.
Jack Hilkewich
May 9, 2006 at 3:32 pmAfter you “Make Movie”, which is adjust your settings etc, you then “Render” your movie, this will then output a sequence/file/.mov/.avi/etc.
Aharon Rabinowitz
May 9, 2006 at 3:36 pmThe work flow is like this:
Work in AE > Make Movie > Render
After you hit Make movie and set everything up then you render.
It is not the same thing, but eventually, yes, Make movie does lead you into rendering.
In fat, you can’t Render, unless you first “Make Movie” (although you can Export video which is a can of worms I want to avoid for this explanation…)
But again, adjusting your car seat and mirror (make Movie) are not the same thing as driving (Render) to your destination (Final Video). They are part of the process of getting prepaired for the drive.
Aharon Rabinowitz
Steve Roberts
May 9, 2006 at 4:04 pm“Make movie” is what you select to set up a render. In AE, you have to render in order to create something useful.
In AE, “render” means “create a digital file on disk”. That file could be a digital video file, digital still file, digital image sequence or digital audio file.
Now “export” is used when creating special kinds of renders, such as SWF files. Why they’re listed separately, I don’t know, but it could be that they don’t use the render queue in the usual fashion.
By the way, most users rarely use “export”. Selecting “Make Movie” or “add to render queue” is normal procedure.
Aharon Rabinowitz
May 9, 2006 at 4:06 pmAdd to Render Queue is the same thing as Make movie – near as I can tell. In the past there may have been a different functionality, but i don’t see that now.
Aharon Rabinowitz
Erin Patrick
May 9, 2006 at 4:11 pmOh, Ok. Everything is much clearer now. Thank you, everyone for posting.
Hopefully this thread will help someone else out in the future.
