Activity › Forums › Blackmagic Design › Difference between Multibridge HD & Multibridge Extreme?
  • Difference between Multibridge HD & Multibridge Extreme?
    Posted by Troy4243 on March 28, 2006 at 10:54 pm
    Trying to figure out the difference between the Multibridge HD ($1,814) vs. the Multibridge Extreme ($2,499). All I can figure out is that with the Extreme you don’t need an HDLink to connect to an apple external Monitor for your HD monitor. Is that right?
    thanks
    -Troy-
    FCP5 HD
    BlackMagic Decklink
    Dual 2.7ghz G5
    2gig RAM
    OSX 10.45
    Kristian Lam replied 20 years, 6 months ago 2 Members · 3 Replies
  • Kristian Lam
    March 28, 2006 at 11:47 pm
    Hi Troy,
    Not only that.
    The Multibridge Extreme also supports 2K playout via the DVI-D to a 30″ display. It can also be connected to your PCI-Express G5 via the provided PCIe card so that you can capture video directly. The Multibridge HD can only be used as a converter and not a capture device.
    regards
    Kristian Lam
    Blackmagic Design
  • Troy4243
    March 28, 2006 at 11:57 pm
    When you say the multibridge HD cannot be used as a capture device..are you referring to having to use a Decklink HD card? We already have the HD Card. If so, I think the Multibridge HD will work fine for us. thanks
    FCP5 HD
    BlackMagic Decklink
    Dual 2.7ghz G5
    2gig RAM
    OSX 10.45
  • Kristian Lam
    March 29, 2006 at 12:03 am
    [Troy4243] “When you say the multibridge HD cannot be used as a capture device..are you referring to having to use a Decklink HD card?”
    That’s correct. If you already have a DeckLink HD card, then the Multibridge HD will be ideal when you want to capture from analog video sources into your DeckLink HD.
    regards
    Kristian Lam
    Blackmagic Design
