Activity › Forums › DaVinci Resolve › Difference between LUT on Node, and LUT in Config Settings?
  • Difference between LUT on Node, and LUT in Config Settings?
    Posted by Chris Armstrong on December 22, 2011 at 9:35 pm
    Is there any advantage or disadvantage to using a LUT in the LUT config section vs. using one in a node?
    Seems like it would be easier to apply (and enable/disable/swap out) the LUT if it’s configured in that LUT config screen vs. a node? (At least if you’re using the same LUT for the entire project).
    What are the advantage of using it in a node?
    Kevin Cannon replied 14 years, 9 months ago 3 Members · 2 Replies
  • Robbie Carman
    December 23, 2011 at 12:08 am
    [Chris Armstrong] “Seems like it would be easier to apply (and enable/disable/swap out) the LUT if it’s configured in that LUT config screen vs. a node? (At least if you’re using the same LUT for the entire project).”
    You nailed it. LUTs on the config page govern the project while you can be selective with the node based approach – which is nice sometimes for example you might have project with linear video mixed with LOG C
    Robbie Carman
    Colorist and Author
    Check out my new Books:
    Video Made on a Mac
    Apple Pro Training Series DVDSP
    From Still To Motion
    An Editors Guide To Adobe Premiere Pro
    Twitter
    Blog
  • Kevin Cannon
    December 23, 2011 at 3:51 am
    It’s also great sometimes to be able to apply grades before and after the LUT is applied, if you put the LUT in a middle node. And you might occasionally come across a shot or scene where you want to use a different LUT, even if the source material is all the same…
    KC
    Prehistoric Digital
    PhD Grading Suite
