Activity Forums Adobe After Effects difference between frame blending & RSMV blur
  • difference between frame blending & RSMV blur
    Posted by James Harris on February 17, 2017 at 8:19 pm
    I am compositing some rendered CG footage out of maya, basically a moving car on a road.
    I want the movement to be fluid at 30 fps, so should I aply RSMV blur to my sequence which can simulate motion blur and make thing more fluid or should I simply use AE frame blending option.
    What are the pros and cons of each approach?
    James Harris replied 9 years, 7 months ago 3 Members · 3 Replies
  • Walter Soyka
    February 17, 2017 at 9:28 pm
    With ReelSmart Motion Blur, you can use a motion vector pass from your 3D render to drive more accurate motion blur than you’d get from either RSMB’s or Ae’s native motion estimation.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Kevin Camp
    February 18, 2017 at 12:36 am
    you can also use the timewarp effect to add motion blur… keep the speed at 100, but enable motion blur.
    it’s not as good as RSMB, nor as fast… but it’s free, and I think it will create a better motion blur than frame blending.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • James Harris
    February 18, 2017 at 7:41 pm
    so the options would be like this (in order of qualirty):
    1- RSMV motion blur
    2- RS motion blur
    3-use simple time warp (enable motion blur)
    4-Simply AE frame blending
    4-use twixtor (enable built in blending)
    right?
