Activity Forums Maxon Cinema 4D Difference between current state to object and making something editable?
  • Difference between current state to object and making something editable?
    Posted by Hilary Tsai on February 3, 2021 at 9:22 am
    I’m a little confused on the difference between these two. A lot of tutorials will say “either do current state to object or make the object editable” for the purposes of optimizing for export. But I assume there must be a difference. Can anyone break that down for me?
    Michael Szalapski replied 5 years, 7 months ago 3 Members · 3 Replies
  • Benjamin Priddle
    February 3, 2021 at 4:34 pm
    They are effectively the same thing,
    Making an “object editable” is normally used when referring to primitive objects, and you’ll more likely hear “current state to object” when using mograph tools and cloners.
    Ultimately it shouldn’t make a difference which one you use 🙂
  • Hilary Tsai
    February 3, 2021 at 9:30 pm
    I see 🙂 Thank you! This clears it up.
  • Michael Szalapski
    February 4, 2021 at 12:08 am
    Also, making the object editable is more destructive. Current State to Object makes a copy of your thing as a polygonal object. This is preferred, so you can go back to whatever rig it is you’re making if you need to change something instead of losing it entirely.
    That is, you can Current State to Object a crazy hierarchy of deformers, etc.
