Activity › Forums › Adobe After Effects › Difference between Close and Close Project in After Effect’s File menu
Posted by Sebastian Lee on February 8, 2013 at 2:50 pmWhat is the difference between Close and Close Project in After Effect’s File menu
Vishesh Arora replied 13 years, 6 months ago 3 Members · 2 Replies -
Zach Meissner
February 8, 2013 at 3:00 pm‘Close’ will just close the comp window in the timeline viewer. ‘Close Project’ actually closes the file you’re working on and gives you a blank slate.
Vishesh Arora
February 8, 2013 at 5:40 pmSebastian
To add on what Zach ahs said:
“Close” option will close the composition and has a shortcut key ” Cntl + W”. If you press ” Cntrl + Alt + W “, All the composition from the Timeline will be closed.
I use this shortcut when too many comps and pre-comps are opened in Timeline just to clean up and then open only the required one.
Vishesh Arora
3D and Motion Graphics Artist
Films RajendraBlog:
https://digieffects.wordpress.com2011 3D Demo Reel:
https://www.youtube.com/watch?v=lHPgIJU_BR8
