Activity Forums Apple Final Cut Pro Legacy Difference between Blackmagic NTSC Jpeg and 10 Bit Codecs
  • Difference between Blackmagic NTSC Jpeg and 10 Bit Codecs
    Posted by Lee Burrows on November 25, 2006 at 8:31 pm
    Hello everyone. I hope that everyone had a nice turkey day. I have a Blackmagic
    extreme capture card and have often wondered the difference between capturing Analog SD beta tapes in eith NTSC-Jpeg or 10 bit codecs? Or even 8 bit for that matter?
    Now I have always been told that 10 bit is as good as it gets and that the BM NTSC Jpeg codec has a 2-1 compression ratio. However if I am capturing it from analog beta will the different codecs really make a difference in quality? Now I know the BM 10 bit files are the biggest in size and look good but I can’t even really tell a difference when comparing it to a BM NTSC Jpeg clip. And if you are cutting features for TV and there isn’t a noticable difference in the quality between the 2 codecs but it saves you space by working in BM NTSC Jpeg…is it the way to go? Am I assuming something wrong?
    I have been told that working in a 10 bit sequence allows more of your effects to be real time and other features that a Jpeg sequence doesn’t offer but I haven’t noticed anything different to this point. Are there? I appreciate anyones thoughts on this subject.
    Happy Holidays
    Lee
    Mac OS X (10.4.7)
    1.5 GB DDR SDRAM
    Dual 2 GHz Processor
    Power PC G5
    FCP 5.1.2
    Black Magic Decklink Extreme
    Sony UVW 1800
    Motion 2
    Lee Burrows replied 19 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
