Activity Forums VEGAS Pro Difference between AVCHD & Blu-Ray codec?
  • Difference between AVCHD & Blu-Ray codec?
    Posted by Paul Gregory on November 23, 2012 at 4:17 am
    I would like to know exactly what differences exist between using template AVCHD 1920x1080i with 16,000,000 bit rate as compared to The Blu-Ray template 1920x1081i . The first template seems to include audio & the BLu-Ray one doesn’t.
    I know that the Blu-ray template can be used with DVDA & have menu’s & chapters etc. Can anything be done with DVDA with the AVCHD files. Is there anything else that I should know?
    Thanks in advance
    John Rofrano replied 13 years, 9 months ago 3 Members · 3 Replies
  • John Rofrano
    November 23, 2012 at 5:02 am
    [Paul Gregory] “I would like to know exactly what differences exist between using template AVCHD 1920x1080i with 16,000,000 bit rate as compared to The Blu-Ray template 1920x1081i . The first template seems to include audio & the BLu-Ray one doesn’t.”
    The Blu-ray template creates Blu-ray compliant AVC video elementary stream files (i.e., .avc which is why there is no audio) while the AVCHD template creates MPEG-2 Transport Stream files (.m2ts) with AC-3 audio. The former is ready to be authored onto a Blu-ray disk while the later is not.
    [Paul Gregory] “I know that the Blu-ray template can be used with DVDA & have menu’s & chapters etc. Can anything be done with DVDA with the AVCHD files. Is there anything else that I should know?”
    If you drop the AVCHD files into DVD Architect it will re-encode the audio into a separate stream. This menas your audio will get encoded twice and reduce it’s quality. When authoring for Blu-ray or DVD you should always feed DVD Architect separate video and audio streams.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Nigel O’neill
    November 23, 2012 at 5:26 am
    [John Rofrano] ” When authoring for Blu-ray or DVD you should always feed DVD Architect separate video and audio streams.”
    Is this the same as choosing ‘include audio’ and selecting ‘save as separate elementary streams’ in the render template? I end up with 2 files: m2v and m2a.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 11 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • John Rofrano
    November 23, 2012 at 12:53 pm
    [Nigel O'Neill] “Is this the same as choosing ‘include audio’ and selecting ‘save as separate elementary streams’ in the render template? I end up with 2 files: m2v and m2a.”
    No. What that does is save the audio as MPEG2 audio. That is not a valid format for NTSC DVD’s although some players will still play it. It is a valid format for PAL however.
    What to want is Digital Dolby AC-3 audio. It’s higher quality.
    ~jr
