Activity Forums Broadcasting Difference between 10 pin camera cable and 26 pin.
  • Difference between 10 pin camera cable and 26 pin.
    Posted by Andrew Morales on April 5, 2011 at 3:39 am
    Hi I’m working with my T.V. Production students and we don’t have enough money to purchase 26 pin SDI cables but would standard 10 pin cables do the same job?
    Tim Ward replied 15 years, 5 months ago 5 Members · 16 Replies
  • 16 Replies
  • Chuck Pullen
    April 5, 2011 at 1:26 pm
    I think you are going to need to give some more info Andrew. Cameras, cables, length, application, etc… and you’ll get some good answers.
    Chuck
  • Andrew Rendell
    April 5, 2011 at 1:32 pm
    It’s not really an answerable question without knowing which pieces of equipment these cables are going to connect and what functionality you’re expecting to have.
    I don’t know if this is of use to you https://www.uweb.ucsb.edu/~shahnam/CLSPEC.pdf
  • Andrew Morales
    April 5, 2011 at 8:04 pm
    The studio cameras are Sony DXC-M7 and the control boxes are CCU-M7. The control boxes have both 10 and 26 pin inputs and the cameras have both 10 and 26 pin outputs. From what I have researched the 10 pin cables cost significantly less and supply power to the camera and video from.
    Hope this helps!
  • Tim Ward
    April 5, 2011 at 8:45 pm
    The M7 is 26-pin only. The “10-pin” connector you refer to is probably the 8-pin Remote connector used for the RM-7 remote control panel, or paint box. For studio use (connecting to a CCU), you need the 26-pin (CCZ) cables. These cameras are analog, so you don’t need the “digital”-labeled cables, unless they’re cheaper.
    There may be an alternative that uses the RM-7 instead of the CCU, bundled with a coax cable for genlock, a 4-pin XLR cable for power, a 3-pin XLR cable for beltpack-intercom, another coax cable for a teleprompter, and yet another coax cable for the camera’s composite video output, a 2-conductor cable that drives the add-on tally light that you’ll have to purchase/build to put on the camera (since you can’t use the built-in light)…I may have left out one or two others, but it’s a mess and the cost savings may not be that great compared to just purchasing 26-pin CCZ cables, which you might be able to find in good shape on eBay.
  • Andrew Morales
    April 5, 2011 at 9:41 pm
    Both have 10 pin inputs!!! I shouldn’t have to buy CCZ cables!
  • Tim Ward
    April 5, 2011 at 10:26 pm
    Sorry about the confusion Andrew…I read the wrong thing regarding the RM-7 – it IS a 10-pin connector (not 8-pin), as I just verified with one in my hand. That connector you highlight is for the RM-7, NOT for connecting the camera to the CCU. My above post is correct, except the 8/10-pin part.
  • Tim Ward
    April 5, 2011 at 10:33 pm
    I forgot to add that the RM-7 can be used directly with the DXC-M7 or to extend the CCU-M7’s controls to another location, such as a camera shader’s position.
  • Andrew Morales
    April 5, 2011 at 10:39 pm
    But, the camera cannot connect to the CCU via 10 pin is what you are saying. Is that correct?
  • Tim Ward
    April 5, 2011 at 10:44 pm
    [Andrew Morales] “But, the camera cannot connect to the CCU via 10 pin is what you are saying. Is that correct?
    Yes, correct. It’s only used to connect to an outboard device like the RM-7.
  • Andrew Morales
    April 5, 2011 at 11:09 pm
    Ok. Could you tell me if there is a place where I could find some type of connection for a 4-pin XLR DC cable? Where one end goes into a wall outlet and the other into the camera.
