Activity Forums Apple Final Cut Pro Legacy Didn’t save P2; just have quicktime files-help…
  • Didn’t save P2; just have quicktime files-help…
    Posted by Jonathan Skurnik on October 22, 2008 at 5:57 pm
    Hi there,
    On one of my first HVX200 shoots, where I didn’t understand the workflow at all, I converted the P2 clips to Quicktime files on site (using the log and transfer window), and never saved the actual P2 files. So I only have the quicktime files and no original raw P2 data. I would like a recommendation on how to proceed with these files. Are they lower res than the originals? Should I back them up? Can I somehow convert the quicktime files back to raw P2 data?
    Thanks for any help…
    -Jonathan Skurnik
    John Fishback replied 17 years, 10 months ago 3 Members · 2 Replies
  • Shane Ross
    October 22, 2008 at 6:07 pm
    [Jonathan Skurnik] ” data. I would like a recommendation on how to proceed with these files. “
    Back them up. Just like you would the original files. Just know that now you are limited to ONLY using these with FCP.
    [Jonathan Skurnik] “re they lower res than the originals? “
    Nope. Same quality.
    [Jonathan Skurnik] “Should I back them up?”
    Yup.
    [Jonathan Skurnik] “Can I somehow convert the quicktime files back to raw P2 data? “
    You can’t convert them back into the format that the card records. But I hear that some software (MXF4QT export) will convert it to MXF. But I don’t know for sure.
    Shane
  • John Fishback
    October 22, 2008 at 6:29 pm
    I haven’t done this, but I believe the latest version of Raylight “makes” P2 cards from QT. https://dvfilmstore.com/raylight-for-mac.html
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.4 QT7.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
