Activity › Forums › Adobe After Effects › Didn't Know 3d Triangle so difficult
  • Fabrice Leconte
    January 19, 2021 at 5:00 am
    Hello, your triangles are probably not perfect.
    You can use expressions to draw a triangle.
    you will be sure that they will be perfect.
    createPath(points=[[0,-540],[540,540],[-540,540]],inTangents=[],outTangents=[],is_closed=true)
  • Robert Müller
    January 19, 2021 at 9:02 am
    Your positions are off. Your misaligned triangles are at position[0] (the x-value) 408 it seems. In the linked tutorial they are at 420. Mathematically this makes sense, since you shift the triangle by half the width of the square base. So base is 1080px, half 540, 960 (old x-position) -540 is 420. I guess you messed up while repostioining the anchorpoint, since its a little tricky in 3d space
  • Ella Lifshits
    January 19, 2021 at 12:08 pm
  • Ella Lifshits
    January 19, 2021 at 12:09 pm
    Thanks! i got you and fixed it!
