Activity Forums Apple Final Cut Pro Did I stumble onto something like “reconnect media” in X?
  • Did I stumble onto something like “reconnect media” in X?
    Posted by Bill Davis on January 23, 2012 at 2:32 am
    I’ve mentioned my workflow here before. I shoot DSLR, then in the field use Disk Utility to make Disk Images of the cards as they fill up and then backup those archives.
    Tonight I had a client call for a re-cut on some work from a few months ago – and I noticed that back then, I wasn’t using the proper “MOVE” command and had managed to get all of the clips in a particular event and project disconnected (all of them were showing as red (offline) Icons.
    I figured I was going to have to re-import all the clips from scratch. Thankfully, I didn’t delete them from the Event Browser, but rather just selected one exemplar clip in the IMPORT screen.
    To my surprise, after telling me that the thumbnail (THM) files were missing – X politely relinked to all that cards files and repopulated my timeline and the Event Browser just as “RELINK MEDIA” had done in Legacy.
    I was able to “reconnect” to five cards worth of data in about a minute and was right back like I’d never lost a beat.
    Is “re-import” functionally in X the same as “reconnect media” in Legacy?
    All my disk images are on a firewire drive, and if this proves to be accurate (and it seems to be working for me now) – then as we’ve seen in other cases “reconnect media” is not actually missing, but rather re-named (and possibly limited in ways I don’t yet realize) in X.
    In any case, not having to re-build anything to take care of this client request – even tho I messed up and moved the files manually – is making me feel pretty good right now.
    If everyone else knew this and I’m late to the party – sorry to waste your time. But I’d thought that the entire “reconnect media” thing was gone. And perhaps it isn’t.
    FWIW.
    “Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
    Oliver Peters replied 14 years, 8 months ago 11 Members · 14 Replies
  • 14 Replies
  • Noah Kadner
    January 23, 2012 at 7:50 am
    If you have files that went offline and you then try to re-import the identical, original media back into the same Event, (and FCP X decides they match), they will reconnect. You can do this either via File>Import or simply by dragging directly into the Event from the Finder.
    Noah
    Call Box Training.
    Featuring the Panasonic GH2 and GoPro HD Hero.
  • Lawrence Eaton
    January 23, 2012 at 11:47 am
    I’d agree with you Bill. It’s more of a change in terminology and methodology that comes with FCPX. I’m discovering new and wonderful things with the “Modify Event References” in the last 24 hrs that have gone a long way in restoring my belief that someone somewhere was thinking of mere mortals like myself.
    Lawrence
  • Steve Connor
    January 23, 2012 at 12:26 pm
    [Lawrence Eaton] “I’d agree with you Bill. It’s more of a change in terminology and methodology that comes with FCPX. I’m discovering new and wonderful things with the “Modify Event References” in the last 24 hrs that have gone a long way in restoring my belief that so”
    Please share your discoveries!
    Steve Connor
    “FCPX Agitator”
    Adrenalin Television
  • Brian Mulligan
    January 23, 2012 at 1:03 pm
    No one seems the least bit irritated that little of the functionality of FCPX seems undocumented? Or is that the joy of Apple… the discovery?
    Brian Mulligan
    Senior Editor – Autodesk Smoke
    WTHR-TV Indianapolis,IN, USA
    Twitter: @bkmeditor
  • Andreas Kiel
    As Noah said:
    … (and FCP X decides they match)…
    I still haven’t figured out when and why.
    Andreas
    Spherico
    https://www.spherico.com/filmtools
  • Lawrence Eaton
    January 23, 2012 at 1:05 pm
    Brian,
    It’s that “Alien Tech” thingie… 🙂
    Lawrence
  • Thomas Frank
    January 23, 2012 at 1:07 pm
    What about transcoded ProRes files?
    So there is no relink but more a reimport function.
    Still like a right click on the clip for a relink option.
    But this seems another way… I guess.
  • Oliver Peters
    January 23, 2012 at 1:09 pm
    Was this brought in as “import from camera”? If so, I believe that works much like Log & Transfer in Legacy. L&T allowed a sort of batch import and it’s likely that’s what you are seeing.
    Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Steve Knattress
    January 23, 2012 at 4:50 pm
    The problem I have is that when I move an event any linked (not copied when imported) is now copied to the new drive and is now not indexed but the media is now stored in the event
    If I wish to make any linked media online again as described above it also fully copied despite the preferences telling it not to
    Over Christmas I did not have access to my raid just my archive drive when I moved the event to the raid from internal all of the media was copied from the archive to the raid not what I wanted
  • Craig Russillroy
    January 24, 2012 at 12:57 pm
    I had a nightmare last night where i have done the following;
    FCPX to OMF with the free duck, once created wouldn’t open in Soundtrack so went lets try Audition, no luck either …. went back into FCPX and my External Audio files were offline, he is me thinking – oh shared programs – nope files would not reconnect for anything – – Dup Projects, Nope, Modify , Nope Swearing nope ! re-import – nope (get the picture)
    After HOURS of abuse and a good part of a bottle of red wine i admitted defeat and went to bed.
    I tried again this morning – nothing, so I went outside the box ……
    Exported a XML, then reimported it back in – BOOM media relinked !!! I deleted the project i imported in from the xml and all is good again
    Hope this works for everyone else cause that was a horrible night !
    Also I have to say the Xto7 app is amazing – best investment ever – as i managed to get my files to STB via FCPX -> xto7 -> send to Soundtrack – worked a charm
    Adstream London, England
    4 x Mac Pros, FCP7, 4 x Flip Factories, 35 x Rhozet Carbon Coders, Offices Globally
