Activity › Forums › Apple Final Cut Pro › Did 1.0.4 Kill Magic Bullet?
Posted by Jim Giberti on April 13, 2012 at 6:29 pmAs I finish the project we’re on now looking forward to updating to 1.0.4 I read that it has broken MB, which would rule it out for us until it’s fixed.
Anyone know if this is true?
Michael Hadley replied 14 years, 5 months ago 7 Members · 19 Replies -
Jim Giberti
April 13, 2012 at 6:32 pmAnswering my own question – Yes Jim, it is broken and not advised to update yet. Red GIant is aware of this and fixing asap.
Steve Connor
April 13, 2012 at 6:52 pmIt seems to be just the preview window which is inverted, everything else seems fine. It’s not ideal but it can still be used
Steve Connor
“FCPX Professional”
Adrenalin Television -
James Cude
April 13, 2012 at 7:41 pmYeah it actually sounds like something that was fixed in 10.0.4 that MB was working around- now they just need to update and it will be all set. The MB plugins still renders fine- just the preview is mirrored. Other than that no biggie. More details here.
Oliver Peters
April 13, 2012 at 7:46 pm[James Cude] “The MB plugins still renders fine- just the preview is mirrored. Other than that no biggie.”
Interaction, when left unrendered in FCP X, also feels a lot more sluggish. This bug is apparently related to any plug-in using an external UI. So far that also includes Sapphire Edge, which is affected in the same way.
– Oliver
Orlando, FL
http://www.oliverpeters.com -
James Cude
April 13, 2012 at 7:57 pmYep- I’d expect an update will be forthcoming from GenArts as well.
James Cude
April 13, 2012 at 9:14 pm -
Oliver Peters
April 13, 2012 at 9:30 pmIt fixed the invert problem. Performance is extremely sluggish. Definitely has to be rendered. Seems worse than in 10.0.3 – or at least as I remember it. Same with Sapphire Edge.
– Oliver
Orlando, FL
Michael Hadley
April 13, 2012 at 10:05 pmFolks: would appreciate hearing from others who update to 10.0.4 AND update MB Looks. I’m still on 10.0.3. I’m working on a project where I definitely need MB Looks Cosmo plug so am not sure it’s safe to get back in the water yet.
Thanks.
Jim Giberti
April 13, 2012 at 10:25 pm[Michael Hadley] “Folks: would appreciate hearing from others who update to 10.0.4 AND update MB Looks. I’m still on 10.0.3. I’m working on a project where I definitely need MB Looks Cosmo plug so am not sure it’s safe to get back in the water yet.”
I’ll be updating both on the weekend after I get this project out.
I’ve done a ton of MB works on this so it will be immediately apparent if there’s a performance hit from the fix/update combo.Ironic huh? Get X to perform better and lose performance of your plugs.
We’ll see.
Oliver Peters
April 13, 2012 at 10:29 pm[Jim Giberti] “Ironic huh? Get X to perform better and lose performance of your plugs.”
IS it performing better? I haven’t noticed. No version of FCP X has performed any differently on my Mac Pro running 10.7.3. Ignoring plug-in performance, the general app performance has always been fine, though I find the UI itself is inherently slow, because of all the built-in UI animation.
– Oliver
Orlando, FL
