Activity Forums Apple Final Cut Pro Legacy Diagonal Split In FCP 7
  • Diagonal Split In FCP 7
    Posted by Shitij Kohli on August 28, 2014 at 4:41 am
    Hello,
    I wanted diagonal split in FCP7, for that i did a 8 point Garbage Matte & split the two clips diagonally….but my client wants a black line separating the two diagonal clips.
    As u might be aware that there would not be a separating line between the two clips in 8 point garbage matte (at most a feather)….so then i did some research & i saw this video:
    Final Cut Pro Tutorial #1:Diagonal Split Screen Effect
    https://www.youtube.com/watch?v=MZVd_cU8Ack
    Basically this is a tutorial about 3 way split & there was a psd file attached to achieve this look…i took the file to photoshop to create my own diagonal split…& here i am struck as my photoshop skills are not that great, i am unable to make two diagonal shape layers (actually i do make, but when i take the psd file to fcp it doesn’t open up in layers, as shown in the video).
    Could someone kindly help me in making a diagonal split in photoshop & attach the file….would be highly obliged.
    I have attached the psd file from the Diagonal Split Screen Effect tutorial from youtube.
    Thanks!!!
    Mark Suszko replied 12 years ago 3 Members · 2 Replies
  • Nick Meyers
    August 29, 2014 at 6:38 pm
    Or copy the garbage mate to the other clip,
    Invert it and tweak
    Nick
  • Mark Suszko
    August 30, 2014 at 5:09 am
    Or make each clip its own layer, over a black first layer, and use the mask tool, your black line comes from the offset of each clip relative to the next.
