Activity › Forums › Adobe Premiere Pro › Diagonal Gray Stripes on my clips (not offline)
  • Diagonal Gray Stripes on my clips (not offline)
    Posted by Steven Sproul on October 17, 2013 at 8:49 pm
    When I reopened my Premiere Project file, and I relinked all of my footage. Some of my clips in my timeline sequence had diagonal gray stripes over them and I could view them in the source monitor but not in the timeline monitor. None of the footage is offline, it just won’t play on the timeline monitor for some reason. Help please.
    Tom Laughlin replied 7 years, 5 months ago 21 Members · 26 Replies
  • 26 Replies
  • Peter Garaway
    October 17, 2013 at 8:59 pm
    Those are called “danger stripes” indicating that the track item is linked to a piece of media that doesn’t actually have audio or video that long.
    Peter Garaway
    Adobe
    Premiere Pro
  • Steven Sproul
    October 17, 2013 at 9:02 pm
    Is there a way to get rid of them so that I can see my media in the timeline again?
  • Walter Soyka
    October 17, 2013 at 9:08 pm
    [Steven Sproul] “When I reopened my Premiere Project file, and I relinked all of my footage. Some of my clips in my timeline sequence had diagonal gray stripes over them and I could view them in the source monitor but not in the timeline monitor.”
    It sounds like when you relinked, you relinked at least one clip to the wrong media file. Now the edit is not pointing to the right media, and at least some of them have insufficient media.
    You need to identify everything that was incorrectly relinked (possibly more than just the ones with the danger stripes), find the correct media files, and re-link correctly.
    Walter Soyka
  • Chris Gunningham
    Cut your clip before the point where it runs out of media. You may have relinked to a shorter clip or retimed the clip. Difficult to say without more information.
    Chris Gunningham
    Online/VFX Editor
    Any opinions expressed are solely my own.
  • Steven Sproul
    October 17, 2013 at 9:45 pm
    Thank you for everyone’s help. I just found out the problem. When I had originally edited my footage, I modified the clips that I wanted to be in slow motion and when I relinked everything later, the footage was in slow motion so I had re-modify all of the clips and that fixed it
  • Tad Newberry
    September 2, 2014 at 7:14 pm
    same problem here. short of going to back to reloading the project again and doing all the relinking that way (the thing it asks you to do upon launch when clips have moved), isn’t there a way from within the sequence to right clip on the diagonally striped clip and re-link? if so, i do not see that option…
    thanks for helping out a bonehead!
    __________________________
    FCS3 / Adobe CC
    3.33 GHz 6-Core Intel Xeon Mac Pro
    24GB RAM
    ATI Radeon HD 5870
    …and a few TeraBytes o’ storage
    (then it’s on to PetaBytes, ExaBytes and MosquitoBytes!)
  • Jean-louis
    September 4, 2014 at 3:46 pm
    Same problem for me.
    Re-opening a project done last month, i got some ‘danger stripes’ in some part of my timeline.
    I haven’t move or change the source clips (MXF files coming from a Canon C300. I have tried the replace command, relinking to the same clips without succes.
    I have also tried to delete the rendered files to force the refresh without any result.
    I am working with a PC, Premiere PRO CC and a collegue has exacly the same problem today with his MAC on another project making us think this is maybe related to a recent Adobe update ?
  • Andreas Yannakopoulos
    September 15, 2014 at 5:00 pm
    Had you interpreted any of your clips to another frame rate than they one they were shot?
    I had the same issue on some clips that were shot at 50fps.
    I found the clips in my bin and I right clicked + Modify/ Interpret Footage/ Assume this frame rate (in my case was 25fps). The stripes were gone and my edit got back to normal.
    Hope this helps,
    Andreas
  • Paul Carder
    December 19, 2014 at 12:03 pm
    That’s sadly not the case in this instance.
    I’ve just opened a trimmed project that I archived a month ago to re-version. All of the video clips have the diagonal lines across them and there’s no way the clips are too short as I didn’t archive with handles.
    I’ve found two solutions, or should I say ‘work-arounds’….
    1) What I’m doing is right-clicking on each of the ‘supposedly offline’ clips on my timeline, and ‘revealing in project’. Then I copy that clip (to clipboard), and then return to the clip on the timeline, and ‘replace with clip>from bin’ and that relinks it, so you can see it in your source monitor.
    Luckily I’m only re-linking a promo, and not long-form.
    2) Failing that, I’ve just done a test where I’ve archived my trimmed project to my local HD, rather than remotely to external storage. I don’t get the diagonal lines! Hooray
    Looks like a big that needs to be fixed. I hope someone out there benefits from this!
  • Paul Carder
    December 19, 2014 at 12:10 pm
    I’ve found a very tedious and painful work-around, but I do suggest that Adobe look at this, as the Project Manager isn’t reliable at all.
    What I’m doing is right-clicking on each of the clips on my timeline, and ‘revealing in project’. Then I copy that clip, and then return to the clip on the timeline, and ‘replace with clip>from bin’ and that relinks it, so you can see it in your source monitor.
Page 1 of 3
