Activity Forums Adobe After Effects Expressions D.getDate() “st” “th” “rd” “nd”
  • D.getDate() “st” “th” “rd” “nd”
    Posted by Scott Mcgee on July 14, 2017 at 8:00 am
    Other than the obvious which is add something like
    I = D.getDate();
    if (I == “14”) = {I + “th”}
    and incorporate it in the below. Is there an easier way to add “th” “nd” “rd” “st”?
    month = new Array();
    month[0] = “January”;
    month[1] = “February”;
    month[2] = “March”;
    month[3] = “April”;
    month[4] = “May”;
    month[5] = “June”;
    month[6] = “July”;
    month[7] = “August”;
    month[8] = “September”;
    month[9] = “October”;
    month[10] = “November”;
    month[11] = “December”;
    D = new Date(Date(0));
    “” + D.getDate() + ” ” + month[(D.getMonth())] + ” ” + D.getFullYear()
    I’m probably being a bit thick, but thought I’d ask if anyone has any other quick solutions that to write and Array and if it ends in 1 put “st” etc.
    Also whilst I’m playing around with this,
    Is there an easy way to get something like this to work?
    Day = (D.getDate());
    Month = month[(D.getMonth())];
    If (Day + Month == “July 31”){“” + month[(D.getMonth()+1)] + “1st”)};
    else
    {“”+ Month + ” ” + Day} ;
    I have to export tomorrows date, but adding a plus one to the day is no problem, but if it’s the last day of the month I get July 32 hahaha, but I need August 1
    Scott Mcgee replied 9 years, 1 month ago 1 Member · 2 Replies
  • Scott Mcgee
    July 14, 2017 at 3:43 pm
    I’m an idiot, because I was put them in separate brackets that was my issue
    if (Day == “31” && Month == “July”) {“August 1”}
    Then the below I set up to do “st” “nd” “rd” and “th”
    Unless someone has an easier solution, I’m fine with this way of doing it.
    month[2] = “March”;
    month[3] = “April”;
    month[4] = “May”;
    month[5] = “June”;
    month[6] = “July”;
    if (Day == “2” | Day == “22”) {“”+ Month + ” ” + Day + “nd”}
    else if (Day == “1” | Day == “21” | Day == “31”) {“”+ Month + ” ” + Day + “st”}
    else if (Day == “3” | Day == “23”) {“”+ Month + ” ” + Day + “rd”}
    else
    {“”+ Month + ” ” + Day + “th”};
  • Scott Mcgee
    July 14, 2017 at 5:39 pm
    And as tired as I was when I originally posted this I realised.
    Using this could help hahaha
    D = new Date(D.getTime()+1*24*60*60*1000);
    D.getDate() + “/” + (D.getMonth()+1)
    Not gonna lie, have no idea how it works, other than getting the time of + 1 day, 24 hours, 60 minutes, 60 seconds, 1000 milliseconds.
    But this works to pick the next day and if that happens to be a new month. It changes the month aswell.
    Hurrah.
