Activity Forums Apple Final Cut Pro Legacy DG FastTrack with Final Cut Pro – Possible?
  • DG FastTrack with Final Cut Pro – Possible?
    Posted by David Green on September 7, 2010 at 6:37 am
    Hi all,
    I’ve searched and searched through these forms and found questions similar but never this exact one.
    Is there any way to get an MPEG-2 Program Stream with these settings for a DG FastTrack gig using only Final Cut Pro 7 and Compressor 3.5?
    Video: 18MB/s
    4:2:2
    9 frame GOP
    29.97fps
    4*3 Aspect Ratio (If captioned the file needs to be
    720*486), 720*480 (recommended)
    Interlaced lower Field first
    Audio: MPEG-1 Layer 2
    2 Channels
    48KHz
    20bit
    384Kbps (recommended)
    Acceptable video and audio quality:
    Average digital audio levels must range between –17dBfs
    and –20dBfs (Analog: 0dB @ +4dBm ref).
    Digital audio levels should peak between –10dBfs and
    –12dBfs (Analog: no higher than +3), with a maximum of
    three peaks per second.
    Setup level should equal 7.5 IRE.
    Luminance levels should not exceed 100 IRE.
    Chroma levels should not exceed 120 IRE.
    If I have to, I’ll spring for Episode. But even then, I have only found correct settings for a file with 720×512 aspect ratio, and not a 720×480 aspect ratio.
    David
    Any help would be much much much appreciated
    S Regian replied 15 years, 12 months ago 3 Members · 4 Replies
  • Rafael Amador
    September 7, 2010 at 8:59 am
    No with FC/Compressor.
    The only 4.2.2 MPEG-2 you can make with FCS are IMX and XDCAM.
    However, are you sure that they want “422”?
    I think that the required data rate is too low for 422/Short GOPs (9 frames).
    If was 420, yes you can do it.
    Rafael
    http://www.nagavideo.com
  • David Green
    September 7, 2010 at 1:40 pm
    Yes I am positive they want 4.2.2
  • Rafael Amador
    September 7, 2010 at 3:47 pm
    Hi David,
    I’m afraid you will need something like Episode or so.
    You may ask in the Compression Techniques Forum.
    rafael
  • S Regian
    September 7, 2010 at 9:41 pm
    I use Episode with no problems… and our Dallas DG office requires an additional 16 lines of VBI in addition and that’s supported in Episode. They do indeed require 4:2:2.
    If you have to, you can edit a preset to fit your needs, rename it and save for futures. There should be a “Program Streams” file inside of the Mpeg-2 preset folder.
