Activity Forums Apple Final Cut Pro Legacy DG Fastchannel settings
  • DG Fastchannel settings
    Posted by Dan Hayes on November 23, 2009 at 8:27 pm
    Hi All,
    I need to do an encode for DG Fastchannel with the following specs:
    Video: 18MB/s
    MPEG-2 Program Stream
    4:2:2
    9 frame GOP
    29.97fps
    4*3 Aspect Ratio (If captioned the file needs to be
    720*486), 720*480 (recommended)
    Interlaced lower Field first
    Audio: MPEG-1 Layer 2
    2 Channels
    48KHz
    20bit
    384Kbps (recommended)
    I’ve just purchased Telestream’s Episode since FCS can’t meet their specs. Can someone send me a Telestream Episode settings file that will cover these settings? I’m especially mot sure what settings give you the “9 frame GOP”.
    Dan
    email: djhayes DOT sf941 AT yahoo DOT com
    Jeremy Garchow replied 16 years, 9 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    November 23, 2009 at 9:44 pm
    Telestream will help you out if you call them.
    Jeremy
