Activity Forums Blackmagic Design dfx livekey n stuff
  • dfx livekey n stuff
    Posted by Eyad Hamam on February 26, 2006 at 8:00 am
    Hello,
    I just bought and installed a decklink extreme PCIe on a dualcore G5. Everything seems to be working fine but there are a few things I can’t figure out.
    1- How does Framelink work?
    2- How do I output photoshop to my client monitor through the decklink card? (also for combustion).
    3- How does livekey work and can it be used in conjunction with final cut pro (i.e if I have graphics that I want to key over a timeline can i do it using livekey?)?
    I tried using “help” for livekey and famelink but I get a message saying there is “no help available” for them. Is this normal or did I miss something in the installation?
    thanx
    eyad
    Kristian Lam replied 20 years, 6 months ago 2 Members · 1 Reply
  • Kristian Lam
    February 26, 2006 at 12:16 pm
    [eyad.hh] “1- How does Framelink work?”
    You drop an uncompressed Quicktime movie into the application icon, it mounts a virtual disk image with the individual frames as DPX files.
    You double click the application, it prompts you for a Quicktime format which is then mounted as a virtual disk image on your desktop. You drop DPX files into the disk image and a corresponding Quicktime movie on the desktop gets updated.
    [eyad.hh] “2- How do I output photoshop to my client monitor through the decklink card? (also for combustion).”
    File > Export > Blackmagic Image Export
    Hold down the option key while selecting the option in the menu if you want to change format.
    [eyad.hh] “3- How does livekey work and can it be used in conjunction with final cut pro (i.e if I have graphics that I want to key over a timeline can i do it using livekey?)?”
    You key over a live video going into the DeckLink card’s input. The output of the card has the video + the image you’re keying combined.
    regards
    Kristian Lam
    Blackmagic Design
