  • Posted by Greg Nosaty on July 24, 2007 at 7:33 pm
    Is anyone using the Digital Film Tools 55mm plugin set with FCP6? Have you noticed and extremely long render times or crashing while using them?
    I’ve rebuilt my system from OS up and I’m still crashing every 15 to 30 minutes while I try to color grade in FCP. My next test is to remove all the DFT filters in the show to see if that solves my problem.
    Ideas?
    cheers,
    greg
    Mike Jackson replied 19 years, 1 month ago 2 Members · 1 Reply
  • Mike Jackson
    July 26, 2007 at 3:05 am
    I’m using that plug-in set, and so far no problems… but I haven’t tried every single filter (I do most of my work with 3 or 4 of them, and can go months without touching the rest).
    My render times are longer than I remember, but I’m doing HD work right now with ‘force 16-bit processing’ toggled on everything, so I can’t really compare.
    I’m on an old dual 2.7 though… Are you on an Intel Mac? Could that be part of the problem…?
