Activity Forums Blackmagic Design Device to convert SD to HD?
  • Device to convert SD to HD?
    Posted by Sean David on January 20, 2016 at 5:35 pm
    I have the digital source footage in SD, and want to use it at 1280×720 at the best quality reasonable. I’ve found Instant4K and UpRez but wondered if there is there a hardware device that would do this better/faster than software? I’m using Windows. We have about 3 hours cut in as clips, but the source for those is many more hours, and it would save time and add flexibility to scale the source up instead of just the clips. I don’t have a massive budget, but quality and efficiency is important.
    Sean
    Asus G750JZ i7, 24GB RAM, Nvidia 880M 4GB, Win8.1 64 bit, Adobe CC, Cinema4D Studio 17, and whatever else it takes to get the job done.
    Sean David replied 10 years, 7 months ago 2 Members · 4 Replies
  • Bob Zelin
    January 20, 2016 at 9:24 pm
    what is your digital source footage ? A Hard drive ? A VTR ?
    Does it have an SDI output ? If it does, you need this –
    https://www.bhphotovideo.com/c/product/686604-REG/Blackmagic_Design_CONVMUDC_Mini_Converter_UpDownCross.html
    if it’s a file, this is done in software with products like
    Telestream Episode or Adobe Media Encoder.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
  • Sean David
    January 20, 2016 at 10:02 pm
    Source is a hard drive with a set of large video files, AVI format, lossless compression. I am looking at software options as well, but a reasonable hardware device could take the processing load off of other machines.
    I can also recapture the content from the DVCAM tapes, but would need output back to e.g. a PC, or a reasonable device. I don’t have any of this type of equipment on hand.
    In your opinion, would the quality be better using a hardware solution?
    Sean
  • Bob Zelin
    January 24, 2016 at 2:22 pm
    no, and I hate Matrox.
    Blackmagic and AJA do not make a hardware solution to accelerate the transcode of your software files from one format to another.
    Use Telestream Episode Pro for what you are doing. You will get the best results.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
  • Sean David
    January 25, 2016 at 7:31 pm
    Thanks, I hadn’t heard of Telestream Episode Pro before, I’ll give it a go!
    Sean
