Activity Forums Apple Final Cut Pro Legacy device not remote
  • device not remote
    Posted by Melissa on April 13, 2005 at 12:49 am
    Hello
    For some reason the dv deck we are using is not following the comands I’m giving it through the log and capture window. It’s set on remote, all the capture and video/audio presets are correct. I even trashed the preferences in case they’re currupt. I know its detecting the deck because its showing the correct time code. But when I press play or stop or whatever it wont do anything.
    Any thoughts?
    Melissa replied 21 years, 4 months ago 2 Members · 4 Replies
  • Thaxter Clavemarlton
    April 13, 2005 at 3:55 am
    Uh… what deck IS it?
  • Melissa
    April 13, 2005 at 5:02 pm
    It is a Sony DSR-1500A (DVCam deck)
    April 13, 2005 at 6:06 pm
    [melissa] “It’s set on remote, all the capture and video/audio presets are correct”
    Make sure the remote setting on the deck is in the i.LINK (a.k.a. “FireWire”) position.
    Depending on the options you have installed on the DSR-1500, the remote can be a “serial-type” (9-pin) as well as i.LINK so there should be a setting to tell the deck which kind of remote control you want to use. (May be a front-panel switch or in a menu setting.)
  • Melissa
    April 13, 2005 at 7:16 pm
    Thanks so much! That helped and the deck is now working fine!
