Activity Forums Apple Final Cut Pro Legacy Determining which disk in a Raid is bad?
  • Determining which disk in a Raid is bad?
    Posted by Steve Cohen on September 16, 2007 at 2:47 pm
    I have a Lacie Big Disk 500GB external drive and 1 of the drive is going bad.
    There is really nothing on there right now so losing the info is not an issue.
    I want to buy a 250GB drive and replace the failing drive.
    How can I determine which drive is the bad one?
    Thanks;
    Steve Cohen
    Editor
    O2 Media Inc.
    Steve Cohen replied 18 years, 11 months ago 2 Members · 2 Replies
  • David Roth weiss
    September 16, 2007 at 4:25 pm
    If you are no longer concerned about losing the information on the drives, then format each drive individually rather than as a striped set and see which one fails to initialize. If they both initialize you might find that you have some other issue. BTW, if you have Disk Warrrior it may also help you in determining which of the single drives has issues once you format them as separate drives.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
  • Steve Cohen
    September 16, 2007 at 6:51 pm
    Thanks David;
    That’s kind of what I was thinking, just wanted to see if there were other suggestions.
    Thanks again;
    Steve Cohen
    Editor
    O2 Media Inc.
