Activity Forums Adobe After Effects Expressions Determining Parent Layer Control
  • Determining Parent Layer Control
    Posted by Y. Bar on January 16, 2010 at 4:38 pm
    Hello,
    I have a Camera Layer which is parented to a Null layer which contains rotation and position keys. Is there a way that I could make the Null layer affect the Camera layer, in the same timing, but a little less magnitude ? (for example to move half the way the null layer moves)
    Thanks, Y.
    Will Skinner replied 16 years, 4 months ago 3 Members · 9 Replies
  • 9 Replies
  • Dan Ebberts
    January 16, 2010 at 6:35 pm
    Here’s an example for position. First you need to specify a point of reference (in this case I used the parent layer’s positon at time zero).
    ref = parent.transform.position.valueAtTime(0);
    delta = parent.transform.position – ref;
    factor = .333; // move one third as far as parent (max value = 1.0)
    value – delta*(1-factor)
    Dan
  • Y. Bar
    January 16, 2010 at 7:25 pm
    I guess I should remove the parenting from the camera first if I want the expression to work?
    Cause with the parenting on it stays as before.
    How should I reference the ‘motion’ layer once I remove the parenting ?
    Thanks, Y.
  • Dan Ebberts
    January 16, 2010 at 8:30 pm
    No, the expression assumes the layer has a parent. You need to create keyframes moving the parent around before the expression has any effect.
    Dan
  • Y. Bar
    January 16, 2010 at 9:55 pm
    The parent layer indeed has keys in it, and so the camera layer moves, but always in the same motion as the parent layer, even though I entered that expression and modified the factor value to values between 1 and 0.001 – the motion is always constant..
  • Dan Ebberts
    January 16, 2010 at 11:46 pm
    I don’t have a clue. It works for me.
    You have the camera parented directly to the null, the null moves via position keyframes, and the camera motion is unaffected by expression, is that correct?
    Dan
  • Y. Bar
    January 17, 2010 at 7:04 am
    That’s correct, I have the camera parented to the Null, and it moves according to the Null layer’s movement, regardless of the value I put in ‘factor’.
  • Dan Ebberts
    January 17, 2010 at 7:08 pm
    Sorry, I don’t have a clue.
    Dan
  • Y. Bar
    January 17, 2010 at 7:47 pm
    Okay, thanks, I will try again to get your example to work.
  • Will Skinner
    April 11, 2010 at 9:50 am
    Hi Dan
    I have used this expression successfully for the position, but i can’t get it to work for Rotation. Was it intended for Rotation aswell or does that require a different expression ?
