Activity Forums Adobe After Effects Determine maximum video size on large canvas
  • Determine maximum video size on large canvas
    Posted by Jeff Kesler on February 20, 2010 at 6:02 pm
    I’m creating a grid with SD video elements in a large canvas so I can zoom into each video as they are discussed. When I drop the large canvas (say “grid”-2000×2000) into an SD comp (“final”-720×486), how do I know at what size the SD footage in “grid” is at it’s native resolution in “final” so that the SD footage is not more than 100% and losing quality.
    Thanks-
    Jeff
    Bruce Wainer replied 16 years, 7 months ago 3 Members · 4 Replies
  • Bruce Wainer
    February 20, 2010 at 7:23 pm
    if the sd file is 100% inside the grid comp, and the grid comp is 100% in the main comp, then the sd footage should be full size.
  • Scott Novasic
    February 21, 2010 at 5:16 am
    yes, do not exceed 100% in your main comp.
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
  • Jeff Kesler
    February 22, 2010 at 7:57 am
    Hey Guys,
    I appreciate the feedback, but you are stating the obvious. Naturally I want to keep it at 100% or less to maintain quality. Maybe I didn’t state my question clearly. If I have a SD clip scaled at 40% (for example) in “comp1” that is 2400px X 2400px and I put “comp1” into “comp2” which is 720 x 480, then I scale “comp1” to zoom into the SD clip, at what percentage will the SD clip be at 100%?
    Jeff
  • Bruce Wainer
    February 24, 2010 at 2:19 am
    I don’t know if this is right, but in the first comp you scale to 40% (for example). This is equivalent to multiplying the video by 40/100 (40 per cent). I believe if, in the final comp, you reverse the equation (100/40) the two should cancel out, giving you 100% (100/100, or 1:1) scale. I have not tested this to make sure, but the math seems to work in a calculator.
