Activity Forums Adobe After Effects Expressions Detect which edittext is activated
  • Detect which edittext is activated
    Posted by Rodrigo Aben on September 9, 2020 at 4:36 am
    I’m using Peter Kahrel’s guide to dinamically create an UI and I want to fill the selected edittext with a keyboard entry. Since all edittexts are created on the fly, how do I check which one is selected? My function works fine on the first one but not on the next field. I accidently marked this as basic, sorry.
    var win = new Window ("dialog");
    var maingroup = win.add ("panel {orientation: 'column'}");
    add_row (maingroup);
    var show_btn = win.add ("button", undefined, "Save presets");
    show_btn.onClick = function () {
    var txt = "";
    for (var n = 0; n < maingroup.children.length; n++) {
    txt += maingroup.children[n].edit.text + "\n";
    alert ("Rows: \n" + txt);
    win.show ();
    function add_row (maingroup) {
    var group = maingroup.add ("group");
    group.statictext = group.add ("statictext", undefined, "Left-click +");
    group.edit = group.add ("edittext", ["", "", 200, 20], "Click here and press any key");
    group.plus = group.add ("button", undefined, "+");
    group.plus.onClick = add_btn;
    group.minus = group.add ("button", undefined, "-");
    group.minus.onClick = minus_btn;
    group.index = maingroup.children.length - 1;
    group.edit.onActivate = function(){
    win.addEventListener ("keydown", function (kd) {pressed (kd)});
    function pressed (k) {
    if(k.keyName === "Enter"){
    group.edit.text = "Enter";
    win.layout.layout (true);
    function add_btn () {
    function minus_btn () {
    maingroup.remove (this.parent);
    Rodrigo Aben replied 6 years ago 1 Member · 2 Replies
  • Rodrigo Aben
    September 10, 2020 at 6:41 pm
    Solved! Logical problem actually. I was adding the event listener to the window and not to the actual group. This is the proper way to write it:
    var txt = "";
    win.show ();
    group.addEventListener ("keydown", function (kd) {pressed (kd)});
  • Rodrigo Aben
    September 10, 2020 at 6:42 pm
    BTW, I keep having no ideia of how .onActivate() works. Tryied different things but none of them returns anything.
