Activity › Forums › VEGAS Pro › destructive trim
  • Terry Esslinger
    March 26, 2008 at 8:55 pm
    Make a subclip in the trimmer.
  • Goran Nilsson
    March 27, 2008 at 6:48 am
    I have made a subclip in the trimmer
    but
    the subclip is not saved anywhere.
    I could of course render the subclip
    but I don`t think that everything will be
    preserved.
    I want a part of my video-clip saved as
    a subclip.
  • Edward Troxel
    March 27, 2008 at 12:05 pm
    Vegas is NON-destructive. To do a destructive trim, place the clip on the timeline, trim as needed, and then render to a new file. Finally, you’ll have to delete your original file.
    Edward Troxel
    JETDV Scripts
  • Goran Nilsson
    March 27, 2008 at 12:33 pm
    Ok !
    So I will need another software for editing video-clips.
    Vegas is for putting together video-clips.
  • Mike Kujbida
    March 27, 2008 at 1:07 pm
    “Vegas is for putting together video-clips.”
    As is every other video editor I’ve ever worked with 🙂
    First of all, why do want to do “destructive” editing?
    The philosophy of most NLEs is to leave the original clips intact.
    That gives you the option to do whatever you want to the original clip knowing that, no matter what you do, you still have the original clip as a fail-safe backup.
    It’s only when you render the completed project to another format that you’re doing a “destructive” edit as, once it’s been edited and rendered, you can’t undo any operation you performed on it.
    It’s also destructive as Edward described above (trim, render new, delete original).
    You also have the option of only capturing the clips you know you’re going to use on the project.
    I’ve done 10 min. videos where I’ve shot over 2 hr. of material. I then sit down, screen all the footage and only capture what I need for the project.
