Activity Forums Adobe After Effects Destroying Text
  • Destroying Text
    Posted by Bex0000 on November 25, 2005 at 7:47 pm
    I have just been set a project where i have to destroy text in various ways on after effects. I have sorted out most of the effects but am struggling with burning text, crumbling text, dissolving text, dripping text. Can anyone help me please??? Thankyou
    Andrei Firtich replied 20 years, 9 months ago 3 Members · 3 Replies
  • Steve Roberts
    November 25, 2005 at 9:01 pm
    None of these are included in a preset: you need to “mix your own” effect.
    For burning, you can make the text shrink away by animating a mask downwards or using a comp containing a ramp layer as a gradient wipe, but as for the flame, you’d probably have to find stock footage of a flame and composite it over each letter. Ideally, you’d cut real letters out of cardboard and shoot them as they burn, I suppose.
    For crumbling, you need to work with the Shatter effect. There should be a tutorial on the COW.
    Dissolving …yeesh. Use the gradient wipe or mask method above and add a puddle of water by creating a puddle shaped mask, then applying bevel alpha over it, and compositing a sky image over it to act as a reflection.
    Dripping: Try searching the COW for “blood”. Search the archives.
    Anybody else?
  • Andrei Firtich
    November 28, 2005 at 2:01 am
    For destroying text you might wanna try this. Precomp a layer with some fractal noise, try using something smooth. Apply some blurr to it. Put a 50% grayscale as background. Ue a mask on the fractal noise layer. Now put some keyframes on the shape of the mask of the fractal noise. You want the fractal noise racing thru the screen from whatever direction you want the text destroyed. Then put a keyframe on the greyscale layer to got to 0 opacity once the fractal noise is gone.
    Hope this helps 🙂
  • Andrei Firtich
    November 28, 2005 at 5:46 am
    Sorry forgot the part about applying a distor map to the text layer. Do that put distortion to luminance on both parameters, then tweak the horizontal and vertical distortion to your pleasure. Then select the layer with the fractal noise as your distort map
