Activity › Forums › Apple Final Cut Pro Legacy › Destination controls missing
  • Destination controls missing
    Posted by Terry Hahin on December 16, 2005 at 11:03 pm
    I’m on FCP 4 and the destination controls (little tabs on left of imeline that control which track is chosen as the source) are missing.
    It’s a problem because when I have nested sequences, the destination controls must be set at the highest track containing audio. If not the audio playback is inconsistant and screwy.
    Irritating enough, but now my destination control have disappeared and the manual never mentions anything like this.
    Any thoughts?
    Terry
    Terry Hahin replied 20 years, 9 months ago 4 Members · 4 Replies
  • Aaron Neitz
    December 16, 2005 at 11:08 pm
    Insert tracks until you see them again, then move them down to the lower levels.
  • David Bogie
    December 17, 2005 at 8:37 pm
    I haven’t used FCP4 for a long time but the destination controls cannot disappear. You may not see them if they are off the bottom of the screen on, say, audio tracks 15 and 16. If your clip in the Viewer has no audio content, there are no audio destinations presented. Your other statement about bad playback is of far more interest.
    I”m nut sure what CharlieX2 means by “insert tracks till you see them” but it sounds like an interesting thing to try.
    You think the destination selectors are weird? Wait ill you get FCP4.5 and encounter the thrice-damned AutoSelect.
    bogiesan
  • Kim Rowley
    December 19, 2005 at 3:25 pm
    This has happened to me too a couple of times for no apparent reason. There was clearly audio on the source (I can hear it in the viewer!) but the audio source indicators in the timeline are missing and even if I try to edit the clip -(video and audio) into the timeline- there is no audio clip – as if it didn’t exist. I ended up selecting the entire sequence (command+A) and copy and pasting the entire thing into a new sequence. The indicators reappeared in the new sequence. I still don’t know what caused the problem, but it’s a workaround in a pinch.
    Dual 2.7 GHz G5, 4GB RAM, ATI Radeon 9650, Xserve RAID, AJA IO, 2 20″ Cinema Display, FCP 5.03, OS X10.4.3
  • Terry Hahin
    December 19, 2005 at 6:20 pm
    Thanks everyobody for the suggestions.
    In dealing with it, I found there to be little to fix it, other than simply restarting FCP, but it works. Then they’ll go away again, restart etc.
    Terry
