Activity Forums Adobe Premiere Pro Desperately seeking 25fps! Only 1 day left to export and it keeps coming out at 24.64fps
  • Desperately seeking 25fps! Only 1 day left to export and it keeps coming out at 24.64fps
    Posted by Christopher Tegg on May 31, 2013 at 5:40 pm
    Hi there.
    I am finishing off my cut and exporting prores422(HQ) media.
    All of my sequences that are duplicated from the same seq are exporting at 25fps.
    Except one.
    The one that is going to online – video only.
    It has now for the second time exported at 24.64 fps.
    I tried copying it to a new seq and I did a 10min export test.
    It worked and was at 25fps, but when I did the full 2 and half hour export was still at 24.64 fps.
    Funny thing it imports back into premiere pro at 25fps and matches the cut?
    Any ideas?
    Cheers
    Chris
    Christopher Tegg replied 13 years, 3 months ago 4 Members · 11 Replies
  • 11 Replies
  • Angelo Lorenzo
    May 31, 2013 at 5:44 pm
    What app are you using to read the frame rate as 24.~~~? And a screenshot of where you’re seeing this number.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Christopher Tegg
    May 31, 2013 at 6:13 pm
    Here is a screen shot.
    Im using quicktime.
    Have also used media info.
    It is saying the same thing.
    Cheers
  • Tero Ahlfors
    May 31, 2013 at 6:41 pm
    Do you have any empty bits of track in your timeline or have you generated black video to fill blank spots in the timeline? I’ve had the same kind of problem when encoding to Prores and the only way I could work around it was to make black video from AE and use that if I needed to have empty spaces in my edit.
  • Christopher Tegg
    May 31, 2013 at 6:58 pm
    ok/
    Will try this.
    Thanks.
  • Christopher Tegg
    June 1, 2013 at 8:58 am
    Hey.
    Tried and failed.
    Still at 24.64fps
    Funny thing is when I export it into premiere it reads as 25fps.
    It also matches cut for cut.
    I bamboozled.
    Any other ideas folks.
  • Tero Ahlfors
    June 1, 2013 at 6:59 pm
    Render the exported file again with the same settings.
  • Christopher Tegg
    June 1, 2013 at 7:05 pm
    How do you mean?
    Like take the exported prores quicktime, put it in a seq, then re export media at the same setting?
  • Christopher Tegg
    June 2, 2013 at 2:44 am
    Thank you.
    There is an editing god.
    You are my hero!!!
    Thanks. Really.
    Chris
  • Tero Ahlfors
    June 2, 2013 at 6:35 am
    This is a horrible Quicktime issue that has bit me earlier. The file is “correct” in Premiere but the framerate is tagged incorrectly in the file metadata that shows in Quictime player and other softwares that for example some broadcasters use.
  • John Pale
    June 3, 2013 at 12:35 pm
    If you know someone with Final Cut Studio (not FCPX), you can use Cinema Tools to fix this instantly without re-encoding.
    Just open the file in Cinema Tools and use the conform feature to conform it to the proper frame rate. Since the file really is the proper frame rate, this only changes the metadata that QuickTime uses to determine the frame rate. Takes about 2 seconds and its fixes,
