Activity › Forums › Panasonic Cameras › Desperately NEED HELP! Charg
  • David Battistella
    August 25, 2005 at 5:08 pm
    You might want to try to find a solar power solution. I am not sure how close you are to that but a few solar panels are lightwieght and use the sun to charge stuff.
    David
  • Tim Scarpino
    August 25, 2005 at 10:29 pm
    When you return, I’d be curious to know why the generator was confiscated.
    Nonetheless, you might try to find some kind of DC-to-AC power converter that plugs into the cig. lighter. At the very least, you can charge the batteries as you drive in the car. You could then probably gerry-rig some kind of wires to make it work on the mountain. A couple of car batteries fully charged should allow you to recharge several times…….
    Good luck….
    Tim
