Activity › Forums › Compression Techniques › Desperate need of compression advice using Compressor/Final Cut Pro X
  • Desperate need of compression advice using Compressor/Final Cut Pro X
    Posted by Mark Vlasic on October 19, 2013 at 9:06 pm
    Looking to compress a 90 minute feature film into a file around 5GB. I had a post house pull it off at 4.71GB but I made changes and don’t have time to get it back to the post house. Any help would be greatly appreciated.
    Steve Mcgarrigle replied 12 years, 11 months ago 3 Members · 2 Replies
  • Craig Seeman
    October 19, 2013 at 10:10 pm
    High school math.
    A car goes 50mph for 2 hours so it traveled 100 miltes
    speed times duration equals distance.
    speed times duration equals size
    kibps times duration equals files sise.
    Solve for kbps.
  • Steve Mcgarrigle
    October 20, 2013 at 5:33 pm
    If it’s afile size issue – remember that Compressor gives you the estimated file size as a calculation in the inspector when you are making your settings. As for what those settings should be? That depends on the files end purpose.
