Activity Forums Panasonic Cameras Desktop Storage Specs for DVCPRO HD
  • Desktop Storage Specs for DVCPRO HD
    Posted by Chris Elley on December 19, 2005 at 10:15 pm
    Jan,
    I have seen a number of tidbits on DVCPRO HD playback performance on desktops & laptops, but could you please reiterate what we all need to be looking for in terms of external storage on our edit systems for full editing capability?
    For instance, do I need to have SATA drives? Do they need to be striped across 2, 4, 8 units?
    Alternatively, can I get solid performance with external drive housings running on a FireWire interface? USB 2.0 interface? Do they need to be striped together?
    Should my realistic expectations include solid singe-stream playback? Better?
    One of the many scenarios I am considering (that falls outside of the interfaces listed above) is the Buffalo Technologies TeraStation unit that comes with (4) 250GB IDE 133 drives in an elaborate housing with processor and RAM that is seen on the Mac as a different computer. The TeraStation connects to the Mac via a Gigabit switch. Their product page: https://www.buffalotech.com/products/product-detail.php?productid=97&categoryid=19
    My System Profile: Mac G5 Dual Processor 2.7 with 2GB DDR RAM running latest Final Cut Pro Studio. Dual 23″ Cinema HD displays.
    Thank you for sorting this out for all of us who are making this transition from tape and capturing to the P2 workflow.
    -Chris Elley
    Electro-Fish Media LLC
    Austin, Texas
    http://www.bbqfilm.com
    Chris Elley replied 20 years, 9 months ago 5 Members · 8 Replies
  • 8 Replies
  • Graeme Nattress
    December 19, 2005 at 11:31 pm
    A normal SATA drive without RAID will playback and record all DVCproHD modes. No need to RAID unless you really want to.
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Toke
    December 20, 2005 at 12:16 am
    TeraStation with raid5 would be perfect file server, but current model has underpowered cpu, so write speed in raid5 is less than 50Mbit/s. I’m waiting for the next fixed model and then buy it.
    It would be also nice to be able to buy hdd’s for terastation separately.
    I have this funny superstition that I trust only seagates nowadays.
    Well, with raid5 wd’s might be also fine if they have 5 years warranty.
  • Jeremy Garchow
    December 20, 2005 at 12:39 am
    [Graeme Nattress] “No need to RAID unless you really want to.”
    ecca2323-
    There’s many advantages to having a RAID. A RAID comes in handy when you can take advantage of redundancy. You can afford to totally lose a drive, keep working, keep all of your data, and sometimes, rebuild the redundant drive in the background while continue to edit. Graeme is right, it is not absolutely essential if you are working in the DVCPro HD codec, but there are advantages. It really depends on your workflow, how much editing you’re doing, if you edit onsite (ie physically move your drives around a lot on airplanes) and how fast your deadlines approach. Buying a more expensive raid will not only gain performance, but it might just buy you piece of mind as well. I know it has me. This means that whatever you choose, you must look for RAID3 or RAID5 capability. the best ones work with a dedicated hardware controller and an HBA (host bus adapter), but some people have luck with SATA Raids. I got in early on the SATA Raid game and got out about 6 months later after I almost lost a job due to lost data. I then went with a prebuilt, preconfigured RAID and have not looked back since. My situation is unique in that I often edit onsite and have to put my drives underneath an airplane and subject them to the likes of the Transportation Security Administration. If you are looking for external fibre channel raids, also look into Huge Systems or Medea products. Both companies have forums on this site.
    Good luck in your decisions and don’t forget to have fun.
    Jeremy
  • Graeme Nattress
    December 20, 2005 at 12:41 am
    Very true. I run my xraid in RAID50 for speed and redundancy, but I can play or capture DVCproHD off the internal SATA drive.
    Graeme
  • Chris Elley
    December 20, 2005 at 2:21 am
    Thanks for your thoughts and suggestions on RAIDs. I’ll definitely look into everything you all mentioned.
    I am also interested in hearing Panasonic’s response to the non-SATA drive scenarios. I would like to really pinpoint what the requirements are of DVCPRO HD. At this point, I feel like my understanding of the codec’s demands is not complete.
    Thanks again,
    Chris
  • Toke
    December 20, 2005 at 8:31 am
    Dvcprohd has been edited for years and datarate has been very known 100Mbit/s = 12.5MBps.
    What hdd speed you need depends on how many video streams you want to playback realtime when editing.
    You can check hdd speeds eg. from storagereview.com.
  • Barry Green
    December 20, 2005 at 11:55 am
    Also, the requirements you’re looking for wouldn’t be coming from Panasonic, they’d be coming from the NLE manufacturers. How a particular NLE handles it will differ from NLE to NLE. So check with Apple or Avid or Canopus or whoever you’re planning on using, and check with them what the system requirements are.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available at https://www.dvxuser.com/articles/dvxbook/ and at Amazon (https://www.fiftv.com/db)
  • Chris Elley
    December 21, 2005 at 6:11 pm
    Thank you all. I have since found great information that points me toward external SATA enclosures.
    I found the following links posted on another CC forum as possible external SATA solutions:
    https://store.yahoo.com/firmtek/
    https://www.thedrgroup.com/DRaid.htm
    https://www.macgurus.com/productpages/sata/Burly8RHS.php
    https://barefeats.com/hard57.html
    https://barefeats.com/hard58.html
    Thanks again,
    Chris
